N941WR
Legacy Member
I was just reminded of one of the advantages of running electronic ignition; you can turn the idle way down.
How does this impact your landings? I'll tell you...
I have dual P-mags on my -9 and one day I realized I was having a difficult time slowing the thing down. When I got on the ground I realized I was idling right around 780-800 RPM. A bit high, but nothing bad.
After turning the idle down to around 650 RPM (Remember, with dual electronic ignition you can get a smooth idle, even with a light wood prop.) the plane would slow down very easily, which made it much easier to land.
This may impact the short wing RV's but probably not as much as the -9.
