Guy Prevost
I've searched all over for this, and still haven't found an answer.
To start with, I need to make it clear that I have the new PINK cowl and it may have some other differences, I'm not sure.
I have cut the front edge of the bottom cowl back enough so that I can bring the two halves together. The cut was made along the blue line in the photo below. The little tick mark 1/8" below that is in line with the lip around the spinner bowl.
I understand that I need to trim the top cowling around the spinner bowl to make the spinner bowl round. To do that, it looks like I'm going to have to trim nearly 3/4" off of the sides of the top cowl too. Have others had to do this, or am I missing something?
If the sides of the top do get trimmed, do you just make the cut parallel with the original edge, or do you taper it to some point in back?
Guy
Guy
