I have attached the elevators to the HS and tested the range of motion. I trimmed the skins as called for to provide the required clearance around the counterweights. My question is should I be concerned with the very small clearance between the counterbalance arm and the skin.
I can trim if needed but would prefer not to obviously. REALLY don't want the elevators sticking if they shift a little under load in the air.
Mark Jackson
Mark Jackson
