CDBridgesRV7A
Active Member
Good Day Folks,
In DWG # 3 it says to "trim HS rear spar to allow for elevator control horns to pivot forward and contact the elevator "down" control stop. (See DWG 27A)). When I go to DWG 27A I don't see anything there indicating to trim the rear spar.
When are we supposed to do this trimming? During the assembly of the HS or later in the build process? If it is during the HS assembly, how much do we trim, as I haven't built the elevator control horns yet to see how much room they need.
Any suggestions or help would be greatly appreciated.
Cheers
Chris
Cheers
Chris
