stevemottin
I'm New Here
The picture is of the trim wire bundle exiting the aft bulkhead. It leaves the J-stringer and exits via a bushing in the bulkhead. The tie-wrap point is nearly 4 inches from the bushing. I'm concerned about the wire rubbing on the end of the J-stringer and possibly shorting out or cutting a conductor.
Has anyone seen this issue and how did you adress it?
I'm considering placing a piece of slit tubing around the wire where it exits the stringer.
Steve Mottin
RV-12 N255SM (reserved)
Lake Saint Louis, MO.
