Fearless
I see on the plans that the trailing edge on the trim tab should be aligned with the trailing edge of the elevator. After I have drilled the holes on the hinge for both sides, mine seems to go a little beyond the elevator trailing edge. Is this going to cause me a big problem? I aligned the edges on the spar/trim tab to the notch part/teeth of the hinge on both sides thinking this should be correct. Sorry don't have the plans in front of me to use proper terminology.
Thanks in advance for replies
