mototopo
I just drilled the piano hinge to the trim tab following the directions and measure shown on dwg 4. I ended up with a little edge distance problem: the center of the holes on the hinge are at 5/32 from the rear edge of the hinge and not at 3/16 (alias 6/32) as it should be (2D of 3/32 rivet).
Is it good or did I misread the plans??
