I think the issue is that the RV9 horizontal and elevators are HUGE as compared to the other RVs. Miniscule trim movements have a big effect. For me, unless the trim is neutral, the stick forces are substantial when trying to maintain the desired rate of climb or airspeed on takeoff.
I have stick mounted trim switches and use them alot in the pattern. Climb, downwind, base, and final. It just makes for a nice, relaxed pattern when I don't have to fight the stick pressures.
Anticipating trim usage with different throttle settings is a must for the -9, otherwise you end up fighting the horizontal for control of the plane. I don't know about the other RVs, but I suspect it is less of an issue.
