tomkk
My stabilator trim is very sensitive in cruise. A brief tap of the switch can put it from a nose up trim to nose down trim and it's difficult to get in between those.
The trim motor takes 25 seconds from full up to full down, so the basic setting is within spec.
I can adjust the pot on the Control Module to adjust the motor speed but it's trial and error and I'd have to remove the cover skin for each trial. I was hoping someone else might have had a similar problem and already gone through this.
So, if anyone has adjusted the trim motor speed, about how much change in the pot produces a noticeable change in trim sensitivity?
