I have ordered a new trim rocker switch after the trim stopped working again. Van's said there is trick to replacement of the rocker and I should go here to see if some else has done it. I'm on my second trim motor, have adjusted the pot, reconnected the connects at the motor, and it was working fine for a while, then just stopped.
