Hello this fine sunny day!
I have managed to mess up what should have been an easy task.
I could use a suggestion before I add to my scrap pile.
I used Nas rivits (aka oops rivits) and Cs the reinforcement plate and squeezed those rivits on installing the CS style plate nuts. I was thinking I didn't need to Cs the screw hole since I'd be countersinking the access plate screw holes instead of dimpling. Well, those holes got way to big while countersinking so I decided to try the dimple. The #6 screw seats nicely but now I needed to dimple the reinforcement plate and I already have the K1100 plate nuts installed. So without thinking it throuh I tried to Counter sink anyway and as you can see from pic it was not good idea. The edge broke away and is basically a hole. The dimpled plate rests in the counter sink plate nut just fine though.
Question: can I do thAt to the other 6 screw holes?
Or can I remove plate nuts and try dimpling the others even though I started a counter sink already? Or
Flatten dimple in access cover and continue CS even though it gets wollard out.
Or just order new pArt and dimple it all this time?
![379381bc.jpg](/proxy.php?image=http%3A%2F%2Fi1224.photobucket.com%2Falbums%2Fee372%2Fkatocriss%2F379381bc.jpg&hash=442813a09c99df0e6b95490d2d984b67)
