My RV12 trim’s up but will not trim nose down with either stick pickle switch. Fuse is ok, just wondering if anyone else has had this problem and what was the fix. Thx
Keep’em flying
Keep’em flying
I am unfamiliar with the RV12 provided avionics setup, including pitch trim controls HOWEVER most twin stick aircraft having Elect trim switches on the stick utilize a trim controller of some sort that arbitrates control of the trim servo preventing Pilot from commanding UP while Copilot is commanding DN - this is done with relays. The Trim servo is simply a DC motor, trim direction is typically just swapping the two wires - also done via the relay controller. My thoughts: If the trim UP works but Down does not - the problem lies with the controller relay logic. In Advanced Flight EFIS systems (& some Dynon) such as AF5600 AND equipped with an AP control panel - this controller function is built-in to the AP control panel AND include trim speed scheduling AND stuck switch limiting to 3 seconds of constant operation (trim run away).
Hope this helps, for more help - tell us more about your avionics suit etc.
Keep’em flying
I used a battery to power the trim actuator, which worked as advertised. Sent the A/P control head to Dynon who fixed the problem n/c. Works fine now.
Thx to all who replied.
