drone_pilot
I'm installing an IO-360-A1A in my 7A. I'm also going with the Andair fuel pump (PX375-TC).
I am at the point of installing the Trim Cable however, there is a note in the instructions that says, "If you have fuel injection, order the longer 191" cable." I assume this is because you need the longer cable to route around the Airflow fuel pump. I currently have the cable that originally shipped with my fuselage kit. It appears that the Airflow pump is very involved plumbing-wise and size-wise compared to the Andair pump.
My question is, can I get by using the manual trim cable supplied in the kit since I'm going with the smaller Andair fuel pump assembly? If I have to purchase a longer trim cable, I'll probably just switch to the electric trim system instead.
As always, your input is highly valued!
Thanks.
Thanks.
