I put my cables in and according to the planes the cover plate underneath with the weld on nut is supposed to be in the middle of the threaded cable end. I did that and I am about a half inch to long in order to put in the pin. I have the coupling on the end threaded as far in as I can go. Has others ran into this and did you take the cover plate off and move the cable inward or anotherwords shorten it up or do I have the adjustment wrong at the other end. It seems to me that the other end would not change anything.
any ideas for me. By the way this is a 10.. Thanks in advance
