Trim Bellcrank and washers
MElstien
Friend
Hello,
Section 11-9 figure 2
I am finally assembling the elevator trim bellcrank on my RV-10. I do not seem to have enough clearance to insert both AN960-416L thin washers on either side. I can fit one easily on and it rotates freely but the second one on the far side creates a tight fit and does not allow the bellcrank (F-1095B) arm to rotate freely. Can I remove the one thin .032 washer and not have any washer on one side or should I redo the F1095C brackets?
Or better yet, can I just substitute the NAS1149D0416H .016 think washer on both sides?
Thank You.
Ordering WASHER, FLAT AN960PD-416L
These are .016 thick washers in Aluminum. It should do the trick.
I also sent an email to VANs for an official answer.
Final Answer from VANs
To close this thread out, VANs said a thinner set of washers is just fine, but they did not sell them.
Thank You.
I will probably buy the following from Aircraft Spruce
WASHER, FLAT AN960PD-416L 0.016 Aluminum.
Final Answer and ability to assist others
I returned home from a business trip and my parts arrived and they work great? I was able to find: Flat Washers NAS1149F0416P on eBay. These are treated steel like the ones VANs ships but they are .016 thick. I also purchased Aluminum washers from Aircraft Spruce. I bought 100 of each. I wanted and used the steel but bought both anyway. Cheap.
If anyone needs some of these for this purpose , as long and I still have them, I can probable ship them out to you in a letter.
Let me know.
Let me know.
Mike,
I sure would like it, if you would send me a couple. I haven't finished up my elevator trims yet. Sent you a PM with my address. Thanks.
I've got a similar situation, except I can't really even fit a single AN960-416L washer in between. So I'm not sure if the thinner 0.016" ones will work either.
I assume it's not advisable to not put any washers at all.
I've rechecked things and the holes seem to be 7/16" and the 2 brackets seem to be parallel to each other.
Any advise on what I might have done wrong, or what I should do to resolve?
Thanks!
192AxOSsLgsx11qkoKXBCkg1FnN6vq4SSeL2mut6cy89Tep_RHwJL_dRSI5L_4hVDBAbT5Y0rZo3Q3vnT5b_TZF6u9AXc8oqGqLKZoRLSr-OU3J5l82i93j38u_FjTkrTRq0QjbLEkzOQld_-aeTbkTmfYNdN_F_apiGcDGlN1q9JzaaK-VADT24sjgendGdn0WvL29iRebD7t_3XFCVIydmdv_9KOaAdqIKy8KwHtsp-H6jUlZJeSUtRlZEzMrnWpXrTl9g44U2oEC8ugWZ-CKVWW9IsaomWmZP3d7VHPGpwOq97Rgidv9cgB3-9seUxT5T3xeocZC3XnUo1MKkiH3JT1_HNDgL_l3R-4LVxq08wbGzOOxBj1DK8-QzrTwkJhh8MasMy-ea3LJThx2E48a3IAxVWH4I0t3YKGRcfVy9ovfXswc_41X5lAftzF57PLmzs5VDxoKuErHBZqXgu0q8AbOLJBdt-bFakr7yw1pXDr82foBSf6KlJp8CgHSr2Ynx7LuXYBsRetSc9lNh1NqaxGkQtgQb_BymVgB6o2tn050M4GJFHZ8C9-hB17PnyDQtLQ-UCBy9qWgIlh27poRVwzMvXtFhq5s7mUJvJEyXQT0T=w601-h801-no
-r_-s8RFGQZ4tn52TDkcJO5uRUh4eS5WrT3HPFl6tHeFdSl3b_t0oLSF8JRgYQ4xFrxvNEvw4v2SU-M6sK_nKO8aSLSjf7Zw-T5hu5UcRlLtkD3-aFZBrCC9aVvai8l4loRHCmN3sQGWLUPcJme27os8Wm7MltpXzMEGAb7bubFvjezmz8zG380PhMrDHGmvOcrKJzVXpabliqmEpCiUHsOmgvGgzZOhKoS3v200ZiozVwUqdaoPV4d-TdD-UoI4n6uNdnqtwBr6gXv-69Ptypx4OIfUjKwZn53LZbo3M9pZRQW-TNxK7SfRQ-CWUWsP1BekTrdtH9UABqtz8cV-LtvcDITRTXMdWBDOUi7ZN_ucyfqqmIUFr0lVXeg-fW0Ngj1XCLhPJ9QIXoSpubORddZBcTJTdRR0I9UBwX1wWfpI3fYx1hBLngvyhhdcusVdch4GQBAg3VgkxQQLIs0c25Easog-7z-AbB6mgLhoLREIeskhcRLJrp6Mgkedu4eARGMsP3MwT-KQEfEslP1IWRMuiEXTfMzDLr-XakoTYpPoWAC4t8y_JWiQ9hJO9DZorMdzTaj4OthtloboTKLqKMG7K888k6-1SvAr31oOx5VbCW4c0HXp=w601-h801-no
q80WsECDf-Trv6wQUoDWA4BjgiYeGvvkYSAV9H6B4cOGdqjjTqxyBvQ11GSZyB-4JBU_KGOTXgpmWNnmU3LPuDpK_hAmoP2zT8tFXkVVQnHINEqsiPEWLtcXTTCCy_g_SYOOHIS5CHC_ZpWWfhGhBX01UQJ3lLYg5rBF6w7Bz6f7BacyKA1mzpYAXOToRo60VibvQPVm24EZ6Vlub696D10AcPs4ajnQ4BlCALw7vRvkiqGOsch62u-KuKcj0aCJC42JwS1DWKqlbA1zS3_zRGUMcwNc6uilAVLtaxMSVZOa_pCgB-TQovEECwq7rVVcLB4vkO6ly9jmiOCns1TCyb6vqUWP8YCpOdG6_BsDX0o739F5IXJn9XvgzA5lihVpQNtZviTPgqy11jmm9spWgir6TdYqamSejjq0DdIH67UQv0QcQFdRkpvIbVkm5sWD_xENq-mL56ZD49r-LkF5VVwGIGb-85jiw_zMSlUFfWVavKa6JftjbMXXROla65wjMYhvkwD1_zao9nuUMOFt0hmkc41ZHSHToCW8VYT8WG2vgPEL3_SNn5y8-VMGPEItYhKGlG6SSAXV9voD0jkE5H_decTlXUtQ1FuqLgUMIGNnASXC=w601-h801-no
