IowaRV9Dreamer
I was trying to get the profile of the square tubing to match the fuselage. The left side was perfect out of the box.. the aft end of the right side needed to come inboard about 1/4 inch. I was using the "jump on frame between blocks" method of precision construction. After a few jumps I moved it about 1/16", so I thought more jumps would move it the rest of the way.
I took 1 jump too far![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![](/proxy.php?image=http%3A%2F%2Fimg44.imageshack.us%2Fimg44%2F1138%2Fdcp6843.jpg&hash=66036d35630ad21e94cbb92e59078f2a)
I'm sure the canopy frame is trashed, after less than 1 day of work. The square tubing is cracked clean thru in the corners.
This will be expensive and time consuming. I was so happy to be back to the project again... now this will surely take the wind out of me.
Maybe it could be welded, but I don't know anyone who does that and then I'm sure it would need to be bent even more. I'd probably just trash it again when I got it back![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I don't recommend the jump technique - even for a 175# builder.
Wondering why I'm building at all....
