IowaRV9Dreamer
I know lots of people are at OSH, but I thought I'd try for an answer anyway...
I've been building away, working on both ailerons at a time. I did my best job countersinking the spar, which wasn't apparently good enough. I didn't think much of it, so I kept on building. Completed the skeleton, riveted on the nose skin / counterbalance, and tonight I was all set to rivet the skins to the main spar.
This is when I found out the holes are too big. The clecos don't hold, and the rivets don't fill the holes. I did get an Oops rivet to work, but I don't think I want to use all oops rivets since the spars are pretty much the only structure in the aileron.
So what do you experts think? I think I need to buy new ailerons! Of course I found this out at the end when I can't reuse any of the parts.
I'd love to hear if this has happened to anyone else.
I found on Clay's website (very bottom of this page) that he avoided this problem by countersinking the spar with the rear skins in place. The nose skin was dimpled per plans. Apparently the 0.016 extra metal in the rear skins gives enough room. Seems OK to me... what do you think?
I always mess up countersinking, even in the slow handheld electric drill.
I'm sad, but I get a company paid trip to OSH tomorrow!
