have a skyview system with a xpndr 261 transponder.
What do I have to do to update from software SW to v2.02
and what will the new software do for the system.
bgl
Might have just been my specific problem. I had made a mistake and tried to hook it up to the Skyview as a 262, which blitzed the programming and it had to be reprogrammed in order to load it properly.
For you it was a send back thing.
It is a user upgradeable feature. Instructions on dynons website. You will need to put a placard on the transponder box itself when complete. If you need step by step, call dynon tech support and they will walk you thru it. Very helpful guys and gals there. I believe it makes it compatible with the ADS-B features.
Don's transponder got corrupted, which is why we needed to fix it, not because it is TSO'd.
Instructions on which buttons to push on SkyView, and the label you need to put on the transponder can be found here:
http://www.dynonavionics.com/docs/SkyView_Transponder_Labels.html
Also, the only reason to update is if you are in the USA and are using an ADS-B IN receiver (Dynon or otherwise).
