Capflyer
I ran into a problem yesterday evening with my GTX327 transponder and hoping some of you with more avionics problem solving experience can help out. ATC could not pick up my transponder transmission. I was getting altitude data from my EFIS and seeing radar returns on the transponder. Apparently it was not transmitting because ATC could no pick up my squawk or altitude. I landed and rebooted my avionics and EFIS then went back up and this time picked me up. After landing at another airport for gas outside the SFRA then coming back home ATC picked me up but 15nm later they lost me. Fortunately I was visual with my home airport at the time and able to land there.
I fly out of an airport in the DC SFRA and no transponder means without question....no flying.
It was over 95deg OAT here and the cockpit was very warm especially behind the panel and foot wells. After landing I decided to pull the transponder from my panel to bring it over to an avionics shop for testing and when I did the box was very hot....as was the rest of the avionics in the panel. Could the high heat cause the transponder to intermittently stop transmitting? I checked and the unit was seated properly. An IFR pitot/static/transponder check was completed with success two months ago and since installing it have not had any issues. This was one of the hottest days I've flown this plane. Anyone have any thoughts to other possibilities?
