Appology up front for asking but I can't find the answer in previous threads and need a real world experienced answer.
Ideally, I would like to bundle all my coax together to get them past the spar and hidden in a piece of conduit. Antennas have been placed and have good spacing. (2 comm, 1 nav/gs, marker beacon, transponder, gps)
Here is the issue. The transponder antenna would require a parrallel coax run for about 6 feet to do so (all coax RG400), then split off and I have about 3 feet of seperation between antennas. Problems on the horizen?
If I need to seperate - how much distance between the lines if they run parrallel?
While I'm at it, are all others OK to run in bundle or do I need to seperate?
