dhall_polo
I've read all the threads on this, but still have a question.
Installed (2) comant bent whips where most comant go, under the belly just behind the spar in the outboard ribs. This puts them 37" apart. Good.
Now, where to put the Transponder Antenna. I've seen a number of places where most people install the transponder antenna. Near the firewall or inbetween the bent whips. To me, both those locations have issues. Comant says 36" from other antenna, so between violates that. And near the firewall seems too close to exhaust.
An good location seems to be just aft the baggage compartment near on the passenger side of the vertical support. It's >>36" from other antenna and a safe distance from the exhaust. Also very serviceable.
Has anyone used that location, or can you think of any issues?
Don Hall
reserved N517DG
finishing and beyond
http://rv7.donka.net
Don Hall
reserved N517DG
