RoselBoysRV
Member
I built the brake that Vans recommends and bent the trailing edge of the rudder. I'm unable to bend any further because the brake is closed to the point where the stiffeners are touching the other side. It appears I got a decent radius, but the skin is still approx 1" above the spar without clecos installed. I'm not sure how to bend the edge any further given the stiffeners are touching the other side. Any comments or suggestions on the current bend and how to proceed would be greatly appreciated. We are first time builders and don't want to plow forward if something is obviously wrong.
Thanks!
Thanks!
