Hi there,
So something has bothered me for a while and I am such a perfectionist that I want to resolve it.
The trailing edges of my elevators on either side of the rudder are not even or pitched at the exact same angle. If one is level (the left side), the right is slightly higher. While the plane flys almost perfectly straight, I am pretty sure its the cause of a slight vibration in the controls. Its not something I am worried about, but it is something I would like some advice on. It appears that the right side was riveted to the round bar that goes across the elevator slightly differently to the left.
1.) I am considering replacing the rudder (with trim tab). Am I likely to get any closer with a replacement. I did not build the plane so would get a builder to make me one.
2.) Is it possible to only replace the 'offending' side of the elevator?
3.) Any other advice on this. The rest of the aircraft is perfect and I only require a touch of right rudder when straight and level at cruise speed.
Any advice greatly appreciated.
Hugh.
Hugh.
