Just finished my front gear leg fairing. Upon mounting it the trailing edge separates. Tightening the screws causes the trailing edge to flare and separate behind the hinge. 1/4" right behind the mount points and 1/8" otherwise. Back out the screws and the gap goes to zero.
One option I can think of is to do the same "liquid shim" that we do for the wheel pants to allow the screws to tighten but not squeeze the fairing. The other option is maybe do nothing. The flare is significant to me, but probably not to anyone else unless they'll be crawling around under the airplane. Not sure how significant this would be in flight.
Thought I'd ask to see if anyone else found the same thing and what you did to solve the problem if anything.
