Towbar?
N29945
Active Member
What is the best tow bar for an RV6A, to hook to the hitch on the front of my lawn tractor to push it uphill into my hangar when I am by myself?
What is the source and about what does one cost?
I have minimal weld skills and material around to make one.
RV6A
RV6 Sold
Privileged to donate 2021, exempted by “no ****” flying bullets.
Assuming you mean "tow bar", I use a plain old Bogert tow bar. The handle can be removed with a spring pin and I have a 5/8 steel rod with a ring welded onto the end that I can insert in its place. It allows pushing or pulling with a vehicle, or use with a handle. If you don't weld, any welder could do it for you in a few minutes for about $20 including the steel. Bogert does make several attachments for just such a purpose if that's easier.
Alternatively, you can get this at Sporty's
