Tosten connections
BGordon
Afternoon everyone,
I have received my Tosten control sticks and am curious how others connected them. One has 11ish wires connecting it and I am soliciting ideas on how they were connected to run forward?
Brandon
I used two nine pin molex connectors on each stick for my military style tolsen grips. These connectors have worked great for five years.
However, if I ever rewire these grips I’d seriously consider using either 15 or 25 pin dsub pin connectors through SteinAir.
d-sub
I have 12 wires on my sticks (more buttons?), so I used 15 pin standard D-Sub connectors. Considering that all the wires on the stick are discrete values (and not needing shielding), I just used a couple extra plastic back shields I had.
Kits are only a few dollars, so a low cost, high reliability connection.
I have used terminal blocks to hook up the Tosten wiring.
https://media.digikey.com/photos/Molex/38770-0110.jpg
If you ever need to remove the stick, this makes it easier than having to cut and splice the wiring later.
I'm installing my panel and I was wrestling with the same problem just yesterday. I happen to have a few of those laying around from another project and never even thought about using them here.
That's a terrific idea! Thanks for the suggestion!
Just me
Here is bow i did it.
