alpinelakespilot2000
Van's lists the torque values for various bolt sizes, with the smallest (an AN3 bolt) requiring 20-25 in lbs of torque. The lowest torque wrench range I have found in in. lbs is 25 (a 25-200 in lb Craftsman wrench). Would this be appropriate for any bolts I will have to use in the project? Is it OK that it starts at the upper range of Van's suggested numbers? This is a $90 torque wrench--and I certainly don't want to spend too much (if any) more--but does anyone have any other suggestions if I need to find one with a lower range?
Thanks.
Steve
Thanks.
Steve
