Desert Rat
On the flap actuator torque tube that goes behind the seats, what torque are you guys using on the AN3 bolt/fiberlock nut combo that holds the Delrin blocks to the F-705 bulkhead assembly?
I really don't know enough about delrin to know if the standard 25-ish inch/lbs for a -3 bolt might deform it enough to cause stuff to start to bind up, or maybe sink a hole into it.
