At hangar and can't find torque for connecting rods on O360A1A. Does anyone know or can check?
R rvator4twa Well Known Member Patron Jun 3, 2015 #1 At hangar and can't find torque for connecting rods on O360A1A. Does anyone know or can check?
K krw5927 Well Known Member Jun 3, 2015 #2 rvator4twa said: At hangar and can't find torque for connecting rods on O360A1A. Does anyone know or can check? Click to expand... For what it's worth, the Superior O/IO-360 overhaul manual says to lube threads, tighten moderately to check fit, then torque to 480 in-lb.
B BobTurner Well Known Member Jun 3, 2015 #3 Lycoming says 40 ft-lbs, with Locktite anti seize, for 75061 bolts. 75060 bolts are tightened until a certain stretch is achieved.
az_gila Well Known Member Jun 3, 2015 #4 It's a little more complex than implied in the previous posts... In this case the Lycoming document is best... http://www.lycoming.com/Portals/0/t...I 1458F (03-06-2012)/Connecting Rod Bolts.pdf
