Getting ready to cleco the top wing skin in preparation for riveting, someone posted that Synergy had a pattern they use, that might be different from Van’s....start in the mid-point on the wing skin and work alternating up and down on the rib as you work simultaneously across the front and rear spar towards the wing root and wing tip respectively.
Cleco/ rivet track:
Green dot= start
Sequence: A1/B1/A2/A3/B2/B3
Is this good methodology or is the “ Synergy way” different or better?
Cleco/ rivet track:
Green dot= start
![oHK.png](/proxy.php?image=http%3A%2F%2Fhalie.com%2Fscale%2F80%2FoHK.png&hash=0e3e2a13c84803e256dd11f941005c73)
![oH6.png](/proxy.php?image=http%3A%2F%2Fhttp%3A%2Fhalie.com%2Fscale%2F80%2FoH6.png&hash=0f50eae9499657cd87cca80e3f7c8f25)
