Thank you very much. Looks like something that can be fabricated pretty easily..You probably need the cowl pin retaining bracket:
FF-00005 Cowl Pin Retention Bracket
store.vansaircraft.com
This might be an RV14 part,or maybe an RV7 part, but no matter. I used it on my RV6:
zoom in to my firewall in the hinge gap.
Works fine. Takes 30 seconds to remove the hinge pins, less than a minute to reinstall.
An RV7Bradon please tell what RV you are building
Kind of what I did except: I had a half inch or so bend in the pins that laid forward in the little slot, almost touching each other, then covered those with an aluminum plate that was screwed into nutplates completely hiding the pin ends. I had to carve grooves in the inside of the plate to accommodate the pins and make the plate lie flat. Easy job with a Dremel tool with a round head. Nothing sticking up. Did the same for the pins at the front of the cowling. And the aluminum plates are flush with the cowl. Sorry no pictures. I might get some today I can send along. Mine is a -4 but the hinges and pins are similar.Brandon if you can - please try to incorporate the pins as done on the RV10 and RV14. I have done it on a 7 build and really like it. I am attaching pictures taken in 2015 during the 7 build. Easy to replicate. Now you have two same length pins that are so easy to install or remove. Also no more ugly bulge while flying where the standard two pins meet.
I did a very similar thing. Works well.Kind of what I did except: I had a half inch or so bend in the pins that laid forward in the little slot, almost touching each other, then covered those with an aluminum plate that was screwed into nutplates completely hiding the pin ends. I had to carve grooves in the inside of the plate to accommodate the pins and make the plate lie flat. Easy job with a Dremel tool with a round head. Nothing sticking up. Did the same for the pins at the front of the cowling. And the aluminum plates are flush with the cowl. Sorry no pictures. I might get some today I can send along. Mine is a -4 but the hinges and pins are similar.
Richard,I did a very similar thing. Works well.
The idea of staring out the windscreen at those two pins sticking up did nothing for me. Before paint I may modify it slightly with a small Al or SS square riveted to the hinge outboard to stop the wear you can see at each side.
I did something similar to SuzieQ. I did NOT want to be looking at hinge pins sticking up as that seemed like it was an incomplete installation. And looked kinda silly, IMHO. I have a small plate on the top cowling held on with 6-32 countersunk screws into nutplates on the back side of a holding plate under the cowl where the hinge would otherwise be. I also carved the underside of the plate to accommodate the pins. My top and horizontal pins are 0.090" which are smaller than the original 0.125". The two vertical sides are still the larger diameter. Smaller pins are MUCH easier to put in/out and allow a slight bit of cowl movement. I was not concerned with the eyelets under the cowl showing and left a small gap, again allowing for slight cowl flexing. It also puts less stress on the eyelets and I have had no eyelets break off. No problems after 1200+ hours. Pictures pending.......... IMHO YMMVRichard,
I am in the process of fabricating the top hinges. I like your idea here with the pin extraction in the center. Could you share some additional pics?
Also, any input on the hinge placement on the firewall side? If you had to do it again would you position the hinge forward to hide the eyelets on the hinge. I just drilled mine and they are positioned like yours above. I am wondering about moving the hinge forward 1/8" to hide the eyelets under the cowling. See my post here.
Cowl Hinge Pin Placement…
All, I just finished drilling the upper hinge for the top cowling to the firewall. I heard that there were RV14 plans that had more detail on the cowling install. After review I realized that my hinge placement might be too far aft. Once I fit the cowl and have a .040” gap for paint am I going...vansairforce.net
Richard,
