John Courte
I'm a little confused by this step, which I'm rapidly approaching. The manual says something to the effect of installing the fiberglass inlet ramps with the cowl halves on and hinge pins in because with the ramps glassed in, the cowl is going to flex a lot less and may not actually allow the hinges to line up anymore.
I may be reading it wrong, but how in the known universe am I supposed to do an inverted fiberglass layup through the cowl inlets and another layup on the transition from the forward edge of the ramp to the cowl inlet itself?
I saw no mention of the acceptability of drilling/clecoing the ramps to the top cowl for the initial fit, then glassing that, which would minimize any drift in the hinges.
How did you install your fiberglass inlet ramps?
