Saville
Hi all,
I have to remove a row of circuit breakers to re-wire one.
They are fairly close together. I need to remove the thin flat nut that is used to secure the breaker to the panel. Is there a special tool that makes loosening the nut easier. I tried a wrench. It got the nut off but not.....gracefully. They are klixons, I believe.
I suspect there's a good way to do this. I will try a hex socket but I don't know if I can get the wall of the socket between the breakers - although they had to be tightened somehow in the first place.
Any ideas welcome.
Thanks!
Any ideas welcome.
Thanks!
