That should get you through the installation; there's nothing really special otherwise. Crowfoot wrench for your prop, maybe. By the time you get to your first oil change, you will want to have a filter wrench on hand and a filter cutter. By the way, I installed a quick drain and don't know how I got along without it. Does that count as a tool or a part? For other service, like the 100 hour/annual, a spark plug cleaner, gapping tool, and differential tester are good.
After that, depends on your equipment and also how far you will be going to service your engine. My LSE ignition doesn't need it, but you may need timing tools for mags. Engine specific tools, such as cylinder base wrenches, ring compressors, and so on. Hopefully you won't need any of those right away; not at all if you intend to let a shop do repairs. Oh, and a hand-held prop tach tool is not a bad idea for verifying your instrument panel tach and setting idle.
