Triumph1974
Hi - Does anyone have ideas on what modified 5/8 inch wrench will work for holding the far outside large nut on an 7A? I need to torch up the wing bolts, and there is just not enough room to get a standard wrench on the one nut that is very close to the leg.... It is the nut/bolt that is the second in for the outside edge of the sides of the fuselage.
If someone already has modified a tool to get to this nut, please share your solution.
Paul
Paul
