Aero_Octaveus
So the big question of the day is how much of the NAS1473-A08 nutplates and stiffner ring assembly should I proseal. The manual states that I don't have to proseal any of it with the stock setup, but I notice on build logs that lots proseal everything when using the NAS nutplates.
My rib tooling holes are awfully close to the edge of my stiffener ring/access cover. I plan to use seal-tite in lieu of the cork gasket...but I do want to run some proseal between the rib and ring to make sure that the tooling hole is properly sealed.
Question is....Being that I am using the NAS1473 nutplates, Should I proseal anything else?
