TMXIO-360 numbers
HSANTIBANEZ
Hi, Im in the final configurating process of the G3X System, so i need some help with the folowing numbers:
OIL Temp red low limit, yellow low range, green normal range, yellow up range, red up limit.
Same for Oil Press, and Fuel Press.
Thak you in advanced,
Regards,
One example: TMX O-360
Actually, I found it quite a bit of working figuring out the all the ranges when I configured my MVP-50. Listed below are the numbers I used but I think I've tweaked them a bit since I wrote them down. At least this will be a starting point for you.
EGT: R: 1650 & above; Y:1401 - 1649; G: 1200 - 1400 Y: below 1200
CHT: R: 400 & above during break-in, then 460 & above; Y: 401 - 459,
G: 212 - 400; Y : below 212
Fuel Flow G: 5.8 - 14.8; R: 14.9 & above
Fuel Press (Carb) R: 8.1 & above; G: 2.0 - 8.0; Y:0.5 - 1.9; R: 0.4 & below
Oil Pressure: R: 96 & above; Y: 81 - 95; G: 60 - 80; Y: 20 - 59; R: Below 20
Oil Temp: R: 240 & above; Y: 201 - 239; G: 130 - 200; Y: 75 - 129 R: below 75
Now that I've written this reply, I think I may need to go review all my setting to verify whether or not these numbers reflect the current state of my settings. I think I'll change Oil Pressure to be: Green 60 - 90 ... and I'm open to suggestions from any of the experts.
