jbDC9
So I'm up to almost 290 hrs (420 landings) and just about due for my first pair of new tires... from the good things I've read here about Desser's retreads, I've already decided to order a set.
My question though, is regarding inner tubes; the ones currently installed are the Leak Guards that came from Vans with the finish kit. They work fine, no leaks and I can go several months before adding a few lbs of air. Is it a bad idea to re-use inner tubes in new tires, or should I go ahead and replace them with either new Leak Guards or Michelin Air Stops?
What'cha think?
What'cha think?
