Had the annual finished. I did some of the usual maintenance upgrades, oil, brakes, plugs, etc..
Also upgraded the valve covers and intake gaskets and changed the oil dip stick gasket so the cowling was off.
Went out and taxied around the airport, very hot and very busy so a lot of braking, a lot of stoping and a lot of waiting.
I have Bluetooth tire pressure sensors on the mains. Monitoring the tire pressure it also shows temperature. The temps pulling into the hangar showed 160 and 140 degrees Fahrenheit.
Again very hot and long day on the ground only. No idea if these tire temps are reasonable or concerning.
