gvgoff99
I recently purchased a Aero Classic Leakguard? tube from AC Spruce. The valve stem came out at a 90 degree angle. The problem is that it was an "L" shaped 90 degrees. This did not allow for a non-stressed alignment of the valve stem with the opening in the rim. The tube that was removed was also at a 90 degree angle from the tube but it had a curve in it similar to a "?" (question mark) that allowed for alignment of the stem with the opening in the rim without putting stress on the tube or the stem. Are there any suggestions for what to order to get the "?" stem? I ordered the 500X5 tube. Thanks
