Tire question on a RV14
RV6-KPTW
Pretty sure I know the answer. I was swapping tires today and found a slash in the sidewall (don’t know how or when).
I am getting good wear out of these - so bummer. Replace?
If I replace the tire, should I replace the tube? Both were installed 6/22.
Tires (AeroClassic 5.00-5 6 ply) running 45 lbs cold
Michelin Airstop Tube 5.00-5
As critical as tires are, I always install a new tube when mounting a new tire. Others may disagree, but in the long run it is cheap insurance!
I had a flat a while ago and the wheel pant paint job alone, ended up costing more than a new tire and tube! (yes, I use a professional paint shop)
I attended a forum at Oshkosh hosted by Goodyear Aerospace Tires. She said the reason you should always use a new tube in a new tire is because they both stretch over time. If you put an old, stretched tube in a new tire it may have wrinkles that can eventually cause a failure.
