That is probably a good pressure for your -3, just wanted to make sure you weren't running high pressure that might aggravate the oscillations.
My RV-6 has some gear oscillation that gets worse as the tires wear unevenly due to high landing counts. I've learned to avoid staying in the narrow speed range while taxiing that initiates the shakes.
