Tbone
Just a few...I promise. After fitting the Canopy frame (WD-716) to the fuse and all the skins to it, along with the canopy stiffeners, with clecoes, I "think" I am ready to start fitting the canopy. The only thing that I haven't finalized is the rear canopy "bows" to the WD 725's. I have adjusted to the required degree bend and fluted to make somewhat flat. I have riveted the canopy frame to the 725's and have a good fit in the C702 (FWD SKIN) to the F771 (Forward top skin). My questions are should I rivet the C702 to the canopy frame at this point? The clecoes would be in the way. ( I haven't fit the struts yet or their brackets to it) and does the Aft top skin ( F744 ) need to be removed for trim work on the plexi? Also would there be a problem not yet fitting the rear canopy bows to the WD-725's yet? Seems that I read that the area could be tricky in a tight fit to the canopy. What would be the correct or "allowable" procedure? Any areas or "gotcha's" to look out for?
Any web sites that show a detailed procedure? Thanks!
