I'm working on the tip-up canopy frame, and I've got it all fitted (well, the front and sides, not the back). I went to a lot of effort with complicated shims, etc. to get a nice fit to the fuselage, and at this point I'm quite happy with it. The forward skin of the canopy frame is currently held on with clecos, and the whole frame assembly is clamped in place on my fuselage. Now, where I am in the process, it's time to start fitting the plexi, which I haven't touched yet. My dilemma is this: Van's instructions would have you trim and fit the plexi with the forward skin of the frame still held on with clecos, and only rivet the skin to the frame later on. I think it would be advantageous to rivet the skin (and the reinforcement kit) now so that the frame gains better rigidity and keeps its shape as well as possible while I'm screwing around with the plexi. I think it would also be safer for the plexi to not have a bunch of clecos sticking out of the frame everywhere, threatening to scratch it.
I see only two problems with my proposed sequence:
1. The top part of the interface between the front weldment and the sides (i.e. the "tabs") needs to be adjusted to accommodate the contour of the plexi.
2. The "ears" in the skin may need additional trimming for the plexi to pass through, according to other builders' experience.
I can see possible solutions to these, but I'm interested to hear from builders that have been there before.
1. With the tabs, how drastic is this adjustment? Can I just give them a little bit of inboard bend now, rivet them, and do any fine adjustment later by filing?
2. With the ears in the skin, can I just trim away some material now based on what other builders have had to trim, and confidently expect that I'll be able to make it fit? Has anyone done this?
3. Any other possible problems with my proposed sequence that haven't occurred to me?
Thanks!
-Roee
Thanks!
-Roee
