Louavul
Attempting to fit and drill the fwd canopy frame (Wd-716) hinge points to the fuse attach pivots. I am confused by what the instructions mean when it says to tape the frame "pulling it tight down on the fuse".
Pulling it down it only contacts the F-721 fwd canopy deck at the aft end of the welded assy, about a 3/16 of an inch gap at the fwd end where the deck piece meets the F-768 subpanel. This is the space for the weather striping I suppose, causing me to think the welded assy should parrallel the fwd deck.
I have read many posts about fitting this piece and the .125 spacers that are supposed to go under the canopy side rails.
Am I also supposed to put a spacer under the aft end of the welded assy where it meets the fwd canopy deck? Seems this would allow for a good transition to the side rails. The plans don't say to do this however, that does not mean that it doesn't need to be done.
I'll freely admitt I'm over thinking this task and the intimidation factor is growing. It's just that I've had this piece welded up previously for stupid mistakes (my welder has added me to his will) and am trying to avoid another.
Many Thanks in advance for any words of direction.
Steven Hild
Belen, NM
RV-7 finish
590SC res
Steven Hild
Belen, NM
RV-7 finish
590SC res
