Tbone
Should the side skins be riveted on first and then the canopy slid down between the two? And should you use any "sealer" between the plexi and the skins? Also what to do about the sticking out "ears" on the tip-up? I have them nearly touching the plexi but not sure on how to stick them down when the fiberglassin' is to be done. One side is worse that the other, not sure why. Seems to me that as the project is progressing it starts to have many issues that have been put off for "later".
