KHartman
I'm New Here
Looking to complete canopy work by fall on tip-up canopy for 7A. Canopy is cut, CS, side and rear skins dimpled. I am at the point of riveting the C-603 side canopy skins to the frame. Instructions say to rivet in place. Easy to do without the canopy in it's final place on the frame.
Questions:
Can the front plexiglass be gently slid in place past the #6 dimples with the side skins C-603 riveted in place ? I'm guessing once in it is for good, paint, add the screws and move on.
Second, some of the protective plexiglass covering & tape needs removed around the edges for fiberglass work and fitting. Pull it back a bit or remove all of the covering. Replace it or keep it covered with blanket for future protection ?
Trying not to overthink this.... again.
Questions:
