I am currently working on my tip-up canopy and fitting the Plexiglas. I have drilled the front and rear glass and doing some final trimming.
The plans call out a 1/32" gap between the front and rear glass, but I wanted a little more clearance then that. So I decided 1/16" gap would work well.
The canopy bow was clamped the roll frame per the instructions and I used the roll frame as my reference for my measurements. My roll frame is 1.5" +/-.005 in width (yes I made very accurate space blocks and clamped the frames very precisely when making the roll frame). Since the roll frame was very consistent in width, it makes a good reference for marking the canopy glass (both front and rear glass).
I used a dozen quick clamps to hold everything in position. However you can only clamp either the front or rear glass at a time not both. This is because you need access to the roll frame for the clamp to grip.
I carefully positioned the rear glass (after final trimming) so that front edge was was 1/32" aft of the center line of the roll frame. Then I drilled it in position. I then removed it.
I carefully positioned the front glass (after final trimming) so that aft edge was was 1/32" forward of the center line of the roll frame. Then I drilled it in position.
With the front glass in position I released the 8 quick clamps holding the canopy bow frame to the roll frame. As I released the clamps I notice the roll frame flex aft a little (about 1/16"). This was a little disturbing because I have the the roll frame and components aft clecoed in position (aft top skin was clecoed as well).
I reinstalled the rear glass and now have an 1/8" gap instead of the 1/16" gap I was striving for.
Rather disappointing.
What are the gaps other builders are achieving?
Paul
Paul
