larrynew
Here's a simple description of how I plumbed the garage for air. YMMV.
1. I used 3/4" galvanized steel piping for the perimeter and 1/2" for each drop leg. I tried to slope the pipe toward every drop to help control moisture. Water goes down, air goes up. On some of the drops, I just used a 3/4" Tee.
2. I used several unions in the perimeter piping. Unions allow you to disconnect the two pipes on either side of the union without turning either pipe to unscrew it. I was able to build the system in sections and put them up one section at a time. It really made it easier to trouble shoot leaks since I could just remove one section and work on it while leaving the rest in place.
3. The basic set-up of each drop is show above. I used 1/2" unions on each branch-off from the drop to allow me to remove it without having to twist pipe. I used brass ball valves on the bottom of each drop as that's where the water will collect. On some of the drops, I added a male air fitting after the ball valve which allows me to add another compressor to the system. If you have a different size filter (3/8" is common), just change the reducer and nipple coming out of the union to that size. On the branch above, I have an oiler in addition to the filter/regulator because this is the place I run most of my air tools. That saves me from having to remember to add oil drops to every tool before use. The other drops don't have an oiler.
4. I used Rector Seal #5 pipe thread sealant from Home Depot and teflon tape for every joint. I first wrapped the threads with teflon tape and then "painted" the Rector Seal over the teflon tape. I tried several variations and this way works great. I used a spray bottle with slightly soapy water to test all the joints and I don't get any leaks.
5. For my compressor hook-up, I just have a drop like shown above but instead of a filter, I have a short length of air hose that attaches to the reducer fitting on the union. By keeping all the drops standard, I can move the compressor or any fitting like the one with the oiler to any location in the garage I want by just disconnecting the union.
6. I have 5 drops in my system. I put the drop I plan on painting from on the last leg. My tool drop is the next to the last. When I bleed each drop, I get very little moisture after the first drop from the compressor which is the way it's supposed to work. There are fancier ways to do this but it works well for me. Some folks have a loop type arrangement at each drop where the pipe first goes up and then back around and down but I didn't have enough room against the wall plus it would add several additional joints for each drop. I didn't keep receipts but it was about $200.
![Snapshot_20100325_2.jpg](/proxy.php?image=http%3A%2F%2F3.bp.blogspot.com%2F_t-s8bxgGUIE%2FS6tpbUikIUI%2FAAAAAAAABG4%2F2JyiQCvd1LU%2Fs400%2FSnapshot_20100325_2.jpg&hash=91f57e6cf9e5f3fac65e6b30acc8c028)
![Snapshot_20100325_3.jpg](/proxy.php?image=http%3A%2F%2F3.bp.blogspot.com%2F_t-s8bxgGUIE%2FS6txX0Hu2XI%2FAAAAAAAABHA%2FempmvrcEQE0%2Fs400%2FSnapshot_20100325_3.jpg&hash=c51dfacf5677e6b10cc4ecdc1336856c)
![Snapshot_20100325_1.jpg](/proxy.php?image=http%3A%2F%2F3.bp.blogspot.com%2F_t-s8bxgGUIE%2FS6tyreRUUsI%2FAAAAAAAABHI%2F4B3m6-15z4I%2Fs400%2FSnapshot_20100325_1.jpg&hash=c872ebcbf21f240b92205bff02869a88)
