With all the platenuts that have to install for new plenum, i found a trick that is a huge time saver.
In the past, I would put a screw/bolt through the hole, screwed it in slightly in the platenut to align a platenut. Then after drilling the attachment holes, I had to take the screw out before going to the next hole.
I put a screw in the platenut and ground the head off. Now just stick the ground off shaft in the hole and drill. Mucho fastero!!!
